PTK Posted December 2, 2014 Report Share Posted December 2, 2014 And following Bob Kromer's suggestion to get rid of that useless, for the J, RAM air helps also. I applied SI M20-93 and removed it. I was pleasantly surprised by the perceptible results. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted December 2, 2014 Report Share Posted December 2, 2014 And following Bob Kromer's suggestion to get rid of that useless, for the J, RAM air helps also. I applied SI M20-93 and removed it. I was pleasantly surprised by the perceptible results. image.jpg Given you need a new air induction assembly and the work involved I think that would be an expensive mod, yes? Quote Link to comment Share on other sites More sharing options...
bonal Posted December 2, 2014 Report Share Posted December 2, 2014 OK that answers my question I am now giving the thread back, that's a real nice J you have there Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted December 2, 2014 Report Share Posted December 2, 2014 Given you need a new air induction assembly and the work involved I think that would be an expensive mod, yes? Â No, it is a very easy mod and you do NOT need a new induction box. Â You simply remove the ram air intake, and rivet a flat sheet over the hole. Â Fiberglass the hole in the cowl (best done in conjunction with a paint job), and remove the ram air cable. Â Make an entry in the logbooks. Quote Link to comment Share on other sites More sharing options...
PTK Posted December 3, 2014 Report Share Posted December 3, 2014 Given you need a new air induction assembly and the work involved I think that would be an expensive mod, yes? Negative! Straight forward and easy. The kit is available from Mooney and procedure is outlined in the SI. http://www.mooney.com/wp-content/uploads/2014/03/sim20-93.pdf Best done in conjunction with paint and/or annual. Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 3, 2014 Report Share Posted December 3, 2014 Negative! Straight forward and easy. The kit is available from Mooney and procedure is outlined in the SI. http://www.mooney.com/wp-content/uploads/2014/03/sim20-93.pdf Best done in conjunction with paint and/or annual. You're starting to win people over with a Cheap Bast$&d post like this. Well done. Who knows, you might be the Cheap Bast$&d for December? 2 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted December 3, 2014 Report Share Posted December 3, 2014 You're starting to win people over with a Cheap Bast$&d post like this. Well done. Who knows, you might be the Cheap Bast$&d for December? Â I went even cheaper... I didn't buy a kit to do the work! Â 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 3, 2014 Report Share Posted December 3, 2014 I went even cheaper... I didn't buy a kit to do the work! Eeeeew... Peter you have some serious competition! Nice Scott. 1 Quote Link to comment Share on other sites More sharing options...
PTK Posted December 3, 2014 Report Share Posted December 3, 2014 Eeeeew... Peter you have some serious competition! Nice Scott.Competition is fierce! I'm still holding cards close to the chest though! 2 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted December 3, 2014 Report Share Posted December 3, 2014 I went even cheaper... I didn't buy a kit to do the work! How much was new induction hardware? Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted December 3, 2014 Report Share Posted December 3, 2014 How much was new induction hardware? A few dollars...some sheet aluminum I already had, a few rivets, some silicone...not much! A couple hours of work. Paint shop glassed the cowl hole shut during the paint job. Sent from my VS985 4G using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Mooney in Oz Posted December 12, 2014 Report Share Posted December 12, 2014 Congrats MooneyPilot. Â Your pride and joy is awesome! Â Can you please advise where you sourced the new switches? Â Thanks, Â Victor 2 Quote Link to comment Share on other sites More sharing options...
NotarPilot Posted January 14, 2015 Report Share Posted January 14, 2015 Yes I would be curious too? Or are they simply newly 3D printed switch covers over original switches? Or entirely new switches? Quote Link to comment Share on other sites More sharing options...
