Scott Aviation Posted September 7, 2014 Report Share Posted September 7, 2014 I bought a new garden tractor recently for towing a 201 and ovation 3 in my hangar. because I am not towing any other brand or style i thought I would have a tow bar built specifically for the 2. first of all Im wondering the width of the shaft the towbar slide into on the nose gear and the diameter of the tubing needed. Anyone have any suggestions on the bar itself, Im thinking offset the square stock so it comes out centre with the tire. at least 6 feet long maybe out of 1-3/4 thin wall square steel with a loop to just slip over a 2" hitch ball? Any thoughts or design ideas? I want to slide the round bar through the nose wheel far enough to come out the other side to put a clevis pin in so it doesn't slip out during towing. I would appreciate any feedback on this idea. I am across the country and don't have access to the planes right now to get the measurements needed. Thanks all. chris. 2 Quote Link to comment Share on other sites More sharing options...
DAVIDWH Posted September 7, 2014 Report Share Posted September 7, 2014 Hmnn, Just completed my ez-go golf cart, tow bar conundrum. The bar is a Th-5 from Aircraft Spruce, fast delivery, no state taxes . Comes as a ring, clevis or ball. $70.oo worth of welding for the cart hitch. On the cart hitch found an adjustable height hitch at Lowe's. This permits the tow bar to be horizontal, not canted, as you would have with just the plain ball. If still inclined to mfg., the photos on line of the TH-5 would be helpful and a complete spec sheet could prob. be obtained from Spruce. Just my experience. Best Quote Link to comment Share on other sites More sharing options...
N9660M Posted September 7, 2014 Report Share Posted September 7, 2014 I've found the Universal Big Bogi from Bogert works well for towing my plane with a garden tractor. Not as cheap as fabricating your own though. http://bogertaviation.com Fly safe - Jim Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted September 7, 2014 Report Share Posted September 7, 2014 I made a tow bar from about $20 worth of pipe from Lowes. Put the ring on the tractor, not on the tow bar. I'm pretty sure I used 3/4 inch galvanized pipe, but I'm not at the hanger right now to verify. Parts list: All 3/4 inch galvanized pipe 2 - 10" threaded pipe 1 - 6' threaded pipe 2 - elbows 1 - end cap (thread finger tight after attaching tow bar through front gear) One end goes through the front gear and attach the cap to keep it from slipping back out. Other end is 90 degrees opposed and is pointing down (vertical). Drop this end through the ring on the tractor. I can send pictures next time I'm out at the hanger. 2 Quote Link to comment Share on other sites More sharing options...
Stefanovm Posted September 7, 2014 Report Share Posted September 7, 2014 I made a tow bar from about $20 worth of pipe from Lowes. Put the ring on the tractor, not on the tow bar. I'm pretty sure I used 3/4 inch galvanized pipe, but I'm not at the hanger right now to verify. Parts list: All 3/4 inch galvanized pipe 2 - 10" threaded pipe 1 - 6' threaded pipe 2 - elbows 1 - end cap (thread finger tight after attaching tow bar through front gear) One end goes through the front gear and attach the cap to keep it from slipping back out. Other end is 90 degrees opposed and is pointing down (vertical). Drop this end through the ring on the tractor. I can send pictures next time I'm out at the hanger. Good parts list. I did the same for my M20E, except that it is a manual one. It is too heavy to carry in the airplane, but real convenient in my hanger. If I put a ring on my lawn tractor, it might make towing outside the hanger easier. I believe that Inside there is not enough room to make it practical. I may try the ring idea if I can figure out how to install one. I used black pipe as it was less expensive and will break before I damage the turning radius of the Mooney gear. I do not attatch cap in manual mode as not needed, but was designed to be done, and the other end is not 90 degrees to make easier for manual mode. Quote Link to comment Share on other sites More sharing options...
Stefanovm Posted September 7, 2014 Report Share Posted September 7, 2014 Another difference, mine has 45 degree offsets so that I have a few more pieces of pipe. This puts the operating end directly in line with the nose wheel as the aluminum fabricated $50 one is. Quote Link to comment Share on other sites More sharing options...
Tony__L Posted September 7, 2014 Report Share Posted September 7, 2014 Subscribe. Quote Link to comment Share on other sites More sharing options...
JasonW Posted September 7, 2014 Report Share Posted September 7, 2014 There are pictures in my gallery of the galvanized pipe solution. It is .75" pipe. Outside diameter is very close to 1". Quote Link to comment Share on other sites More sharing options...
carusoam Posted September 8, 2014 Report Share Posted September 8, 2014 Jason, What did you use to drill the bolt holes? Best regards, -a- Quote Link to comment Share on other sites More sharing options...
laytonl Posted September 8, 2014 Report Share Posted September 8, 2014 Lowes has 3/4" black gas pipe that is not galvanized and easier to weld. 1" square stock works well for the arm. Lee Quote Link to comment Share on other sites More sharing options...
Scott Aviation Posted September 8, 2014 Author Report Share Posted September 8, 2014 Thanks for all the advice. Got my dad to measure the tube size for me, its 1" OD. through the nose wheel and 7.5" wide. Thought I would throw that in here incase anyone else decides to build one down the road. My uncle has a welding and fabrication shop so off I go today to build a tow bar and front bumper/tow hitch for my tractor, I'll post some pics on here when I get a chance. Thanks again Chris Quote Link to comment Share on other sites More sharing options...
Bolter Posted September 10, 2014 Report Share Posted September 10, 2014 When I landed at Stinson Field in San Antonio, the FBO (San Antonio Aviation?) had a tow bar with an overload mechanism, specific for Mooney's. If you tried to turn too hard with the tractor, the tow bar "popped" like a torque wrench instead of putting the load on the famously fragile nose gear. Does anyone have drawings or pictures of that design? I think they said they got the tow bar from Mooney directly. -dan Quote Link to comment Share on other sites More sharing options...
JasonW Posted October 25, 2014 Report Share Posted October 25, 2014 Jason, What did you use to drill the bolt holes? Best regards, -a- I used a cordless drill and a drill bit made for metal. Marked both sides and drilled from both sides. It didn't take very long. 1 Quote Link to comment Share on other sites More sharing options...
apenney Posted June 22, 2019 Report Share Posted June 22, 2019 On 9/8/2014 at 4:36 AM, Scott Aviation said: Thanks for all the advice. Got my dad to measure the tube size for me, its 1" OD. through the nose wheel and 7.5" wide. Thought I would throw that in here incase anyone else decides to build one down the road. My uncle has a welding and fabrication shop so off I go today to build a tow bar and front bumper/tow hitch for my tractor, I'll post some pics on here when I get a chance. Thanks again Chris Did you ever build your bar? I'm looking for the size of the bar I can put thru the nose gear so a tug has attachment points. I'm not at the plane now but you measured 1" and 7.5" wide? This is what would be attached to the bar : Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted June 23, 2019 Report Share Posted June 23, 2019 On mine, I use 1 inch OD steel tube. You didn't ask, but I make the part that extends onto the tube 1 3/4 inches long, past the weld (if that makes sense.) Quote Link to comment Share on other sites More sharing options...
Keith20EH Posted June 23, 2019 Report Share Posted June 23, 2019 Mine is welded up hardware store tubing, not over built, so it is weaker than the tow limits, works well with my E on grass. John Deere 425 has the pin welded to a plate, bolted to the front. Gave up trying to rotate Picts. Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 23, 2019 Report Share Posted June 23, 2019 @Keith20EH‘s rotated pics... -a- 1 Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted June 23, 2019 Report Share Posted June 23, 2019 By using some 1" threaded pipe, I was able to thread on a cap to keep the bar from slipping off the plane. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted June 23, 2019 Report Share Posted June 23, 2019 By using some 1" threaded pipe, I was able to thread on a cap to keep the bar from slipping off the plane. Your nose gear could use some cleaning and painting. Corrosion anywhere on an airplane makes me nervous.Tom Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 23, 2019 Report Share Posted June 23, 2019 Tom, those parts were swapped out years ago.... replaced completely with a collection of similar, but different, 252 parts... +1 for Mooney upgrades. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted June 23, 2019 Report Share Posted June 23, 2019 3 hours ago, ArtVandelay said: Your nose gear could use some cleaning and painting. Corrosion anywhere on an airplane makes me nervous. Yep, this plane was sold, and then bought by an insurance company in exchange for a payout on the policy... and then scrapped. Quote Link to comment Share on other sites More sharing options...
kerry Posted June 24, 2019 Report Share Posted June 24, 2019 12 hours ago, ArtVandelay said: Your nose gear could use some cleaning and painting. Corrosion anywhere on an airplane makes me nervous. Tom corrosion painted landing gear looks better than mine. I think his gear is fine. 1 Quote Link to comment Share on other sites More sharing options...
Planegary Posted June 26, 2019 Report Share Posted June 26, 2019 Here is mine. $25 in materials a bit of welding and a drill press and about 1 hour yielded this 1 Quote Link to comment Share on other sites More sharing options...
FastTex Posted June 15, 2020 Report Share Posted June 15, 2020 I'm pretty much working on the same tow bar/idea. Question: are you guys having issues with the bar trying to unhook from the tractor when you push the airplane back into the hangar? I'm concerned that the welded pin could be an issue and I need a stronger connecting mechanism (hitch?). Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 16, 2020 Report Share Posted June 16, 2020 The L needs to be a few degrees shy of 90°.... Under load it is going to want to open up and think about pulling out if given the chance... Or the part that goes into the nose gear is long enough to come out the other side.... Slide a bolt through a hole it won’t escape that way... Or put a lock through it, so nobody can take your towbar... without stealing the whole plane.... The classic Mooney Towbar isn’t 90°... Some tow bars, There are a few bends used to center the pulling force in front of the nose wheel... How fast are you going to tow the plane... by hand? Or connected to lawn tractor....? You want it locked and not able to slide out, if it is following you.... no prize for errant towing accidents... pilot memories only, not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
