Replacement for the "Fred Flintsone" rotating beacon
Sometimes, Robert, it's not the bulb, it's the power supply.
when I took mine off, I saw stickers warning "High Voltage!" I laughed, hooked up the multimeter and turned it on. Read "0" for a long time, over 30 seconds,then the bulb flashed and the meter read over 500 V. Flashing was very irregular, maybe one now, then in 20 seconds, then five seconds, then a minute, then two blinks just 2-3 seconds apart, then one after 30 seconds, etc. the new LED blinks very regularly and frequently, and is exceptionally bright.
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
  • Replies 78
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
I had one in my Beech Sundowner.  I too rebuilt the motor once and got a few more years out of it.. When it died again, I replaced it with the one Maurauder recommended. Then I found a motor and chang
Anit-Collision Systems.pdf
it works...until it doesn't, what me worry?
Posted Images
Replace it with a Whelen LED beacon.  But, remember to drill a small hole in the beacon top (which is actually the bottom when installed on the belly) and seal the space between the adapter and the beacon's base with clear RTV.
John Breda
Link to post
I'll see what I can find. There's no chance for the old part number, I just wrote it on a scrap of paper and took it to the Whelen booth. Should have the new number in the logbook, I'll look it up in the next few days.
The new one would be all I'd need. I have what is probably the very first strobe system installed in the belly and it has ran its course. Whelen's website isn't exactly helpful in this particular application.
Link to post
  • 1 year later...
On 10/24/2015 at 7:13 PM, Hank said:
What certified LED strobes are legal to install in my 201-style wingtips? There are some nice marker/strobe combos, but none approved for me.  :(
Hank - did you ever find a definitive answer to this?   I suspect I have the identical wingtips on my C, and one of my strobe power supplies seems to be croaking.
I'm looking at the Whelen application guide:  https://www.whelen.com/pb/Aviation/System Requirements/Mooney.pdf
But I'm not sure a retrofit into the Lasar aftermarket wingtips is covered here.
I'm also not sure having the enclosed wingtip would let me remove my belly beacon and gain 20kt.
Anyone here know?
Link to post
Power supplies can be found a junk yards pretty inexpensive and pretty simple to swap. I have an extra 2 or 3.
-Robert
Link to post
On 5/15/2014 at 1:33 PM, Hank said:
When my giant Whelen belly blinker became erratic/intermittent, I copied down all the numbers off the side and showed it to the Whelen guy at SNF. He said, "Wow, that's old. Come over here" and put a new LED unit in my hand. The same adapter plate fit it, and it works well in the belly. I can look up the number next time I have the logs out if you need it.
Don't ya' just hate it when they spend your money like that?  :-)
Link to post
6 hours ago, Marauder said:
Is the hole there? (On the bottom). Every 75 I have seen has them.
My 76 has no rotating beacon either. I use strobes as recognition lights. No plate where a hole used to be.
Link to post
I upgraded to Whelen on my F model: belly beacon, landing light, and wing tip nav/tail light. I did not have wing tip strobes before, so I added some capability. If I recall installed out the door cost was around 2k. Some of that is labor because of adding wiring/switch for the wing tip strobes.
DO IT!! The look and safety make it worth it!
Link to post
I wonder if this was an option on our planes. I always thought a beacon was a requirement.
Link to post
Only one form of Anti-collision is required, so wingtip strobes can take the place of a belly or roof mounted beacon legally. Maybe it was an option on later model airplanes...
Link to post
+1 for the Whelen data sheet Lance posted...
So many details related to the age of the plane...  the rules changed a couple of times over the years.
My 65C swapped out the rotating beacon for a strobe.
  • Better visibility
  • less noise in the audio system
  • less maintenance. Grease hardens in the rotating mechanism...
Link to post
There is no hole, no switch, and no breaker for a rotating beacon on my 75F. There is no indication that it ever had one installed.
(Free speed mod, no?)
Link to post
23 hours ago, Lance Keve said:
Helpful info for sure.  Interestingly, the previous owner put on the LASAR enclosed wingtips, which per my understanding are purely aesthetic, on my old C.  As a utilitarian minimalist, this violates my sensibilities by both adding weight and precluding me from removing my belly flasher, whose $40 bulb I recently had to replace.  I'm still considering LED wingtip strobes but replacing the belly light doesn't seem worth it.
Link to post
