Scott Aviation Posted April 14, 2014 Report Share Posted April 14, 2014 Well my left strobe finally kicked the bucket Any pireps on LED 3-1 wingtip strobe installs. I've got the flat wingtips. I'm looking for bright and sex appeal. Ie. multi flashing etc. Quote Link to comment Share on other sites More sharing options...
Steve65E-NC Posted April 15, 2014 Report Share Posted April 15, 2014 What could go wrong that could not be fixed? Are parts not available? I will save my sex appeal dollars for something that I do not already have. I bet someone on this list has any part that you might need. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted April 15, 2014 Report Share Posted April 15, 2014 Probably just a strobe tube. If you can splice wires, you can get a replacement for about $40. Quote Link to comment Share on other sites More sharing options...
triple8s Posted April 15, 2014 Report Share Posted April 15, 2014 I would advise not to monkey with any of those flash tubes, plugs or wires for atleast 5 minutes after it has been energized. I waited about (estimated) 3 minutes, I was "enlightened" now I wait a precise 5 minutes or more! No kidding...... It hurt! Quote Link to comment Share on other sites More sharing options...
OR75 Posted April 15, 2014 Report Share Posted April 15, 2014 Is it the Hoskins strobes you have ? Quote Link to comment Share on other sites More sharing options...
Scott Aviation Posted April 15, 2014 Author Report Share Posted April 15, 2014 I've got the Hoskins strobes. I already had a power supply toast during my restoration and last night noticed no flashy on my port wing. I haven't started troubleshooting yet. But am getting an annoying capacitor charge sound through the headsets since I bought the plane. The ground wires seem fine. So.....I'm toying with the idea of just switching to LEDs. If it's the power supply again I won't have much choice since parts aren't available. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted April 15, 2014 Report Share Posted April 15, 2014 The whelen power supply will work as a drop-in equivalent part for the Hoskins strobe pack. You switch two wires in the connector to make it go. I recommend the TCF power supply. Quote Link to comment Share on other sites More sharing options...
FlyDave Posted April 15, 2014 Report Share Posted April 15, 2014 The whelen power supply will work as a drop-in equivalent part for the Hoskins strobe pack. You switch two wires in the connector to make it go. I recommend the TCF power supply. I replaced the power supply on my J a few years ago with a whelen and it worked fine. The only issue was the strobe pattern (frequency/duration) was different than the original Hoskins. No big deal but one side flashed differently than the other. Just something to check. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted April 15, 2014 Report Share Posted April 15, 2014 That's what I have now. A Whalen triple flash on one wingtip and a single flash Hoskins on the other. Quote Link to comment Share on other sites More sharing options...
cliffy Posted April 15, 2014 Report Share Posted April 15, 2014 Just curious guys as to how the log book was signed off for the change from one side being Hoskins and the other being Whelen. ? If I remember correctly one is original and the other is an STC install. How can the two be mixed legally? I think Aveo makes some good looking LED position lights that are STC'd. Quote Link to comment Share on other sites More sharing options...
bumper Posted April 15, 2014 Report Share Posted April 15, 2014 I have these on my Husky, excellent quality throughout. Back of unit is milled to slide onto sub mount and then lock on with one set screw - - even the machining is fist rate. http://www.aeroleds.com/shop/category/faa-certified/ Almost $1200 the pair seems pricey . . . until you check Whelen's offering. bumper Quote Link to comment Share on other sites More sharing options...
jetdriven Posted April 15, 2014 Report Share Posted April 15, 2014 Just curious guys as to how the log book was signed off for the change from one side being Hoskins and the other being Whelen. ? If I remember correctly one is original and the other is an STC install. How can the two be mixed legally? I think Aveo makes some good looking LED position lights that are STC'd. Clffy it was done before we bought the plane. But I suspect it is a like for like install since the whelen power supply is similar in size and function. Quote Link to comment Share on other sites More sharing options...
OR75 Posted April 15, 2014 Report Share Posted April 15, 2014 Clffy it was done before we bought the plane. But I suspect it is a like for like install since the whelen power supply is similar in size and function. the power supply is PMA'ed. The STC has more to do with the flashing assembly Quote Link to comment Share on other sites More sharing options...
cliffy Posted April 16, 2014 Report Share Posted April 16, 2014 Like I said I'm just curious at this time as I've never seen this issue before. Normally an STC covers and entire "system" All parts in the "system" have to be made under a PMA process. The general process is to get an "STC" for the "system" then you get a "PMA" to be able to manufacture the parts of the STC approved system. So just because something is "PMA'd" doesn't mean that it can be used in a particular or different STC'd system. I would think it would be akin to doing a 201 STC cowl install but using a 252 cowl because it was a PMA'd part. I think the Whelen strobe light system STC calls for specific parts to be installed and no allowance is given to use say Hoskins parts on the installation. I've never heard of "like for like" in STC'd systems. Is there anything with the Whelan part that says it's a direct replacement for a Hoskins part? Like I said, I'm just thinking at this point. Quote Link to comment Share on other sites More sharing options...
MB65E Posted April 16, 2014 Report Share Posted April 16, 2014 One could argue it's not a major alteration, and no 337 was filed, Parts are TSO'd, and move on? Hurry up part 23!!!!!! -Matt Quote Link to comment Share on other sites More sharing options...
orionflt Posted April 16, 2014 Report Share Posted April 16, 2014 FAA AC 23-27 covers parts and material substitutions for vintage aircraft, basically it says that due to the age of some of the aircraft and the lack of parts being manufactured for them that owners can manufacture or have manufactured replacement parts that meet the specifications of the part they are trying to replace. it also covers the documentation required when using these parts. Brian http://www.faa.gov/documentlibrary/media/advisory_circular/ac_23-27.pdf Quote Link to comment Share on other sites More sharing options...
MB65E Posted April 16, 2014 Report Share Posted April 16, 2014 +1! -Matt Quote Link to comment Share on other sites More sharing options...
cliffy Posted April 16, 2014 Report Share Posted April 16, 2014 AC 23 27 only covers certian parts substitutions and not "owner produced parts" Another AC covers that. Both have very strict requirements on how the parts are to be documented and approved for installation. Unfortunately the AC 23 27 is very specific on how a substitution can be done and in most instances it requires a Field Approval by the FAA. As far as TSO parts go the AC specifically says- "A TSOA does not authorize the installation of a TSO part in a certificated aircraft. The standard procedures for the installation or modification of an aircraft must be followed (i.e., STC, field approval, etc.)." Doing substitutions is no different than the minutia that the FAA went through on the current thread here on the "Junk C Model" and all the picky crap they filed on. If they ever get involved in your airplane EVERYTHING down to the last placard gets looked at for LEGALITY. It doesn't make any difference if it it a small or large issue, it will be noted and filed on. The guy hung on the line is the A&P that signed off on the installation of the strobe power unit. If no A&P signed it off then the owner is the one who the Feds come after as he is directly responsible for full compliance with the FARS and the airworthiness of his airplane (FAR 91.403). I can be said also that even if the Feds go after the A&P the owner can be held responsible due to 91.403 AOPA has a very good article on ownership responsibilities https://www.aopa.org/Pilot-Resources/Aircraft-Ownership/Guide-to-Aircraft-Airworthiness.aspx#1 We just had the Feds here at one of our small operators doing a white glove inspection and they spent one entire week going through every piece of paper, every cabinet, every airplane, every log book compared to what the airplane showed, even looked at the certification dates on the tools inside the mechanic's tool boxes and on and on. I've said it before, you don't want to be "on the fringe of being legal" if they ever investigate you. Yes the new Pt 23 may be a big help if it ever gets done. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted April 16, 2014 Report Share Posted April 16, 2014 Whelen publishes a cross-reference to the Hoskins strobe power supplies here. So, equivalent parts for equivalent function. It's a PMA power supply with cross-reference to the original, no longer available, Hoskins power supply. http://www.whelen.com/pb/Aviation/System%20Requirements/Cross%20Reference%20Chart.pdf Also they detail how to intermix the Hoskins strobe tube to the Whelen power supply here. http://www.whelen.com/pb/Aviation/Catalog%20Price%20Lists%20and%20Manuals/Anti-Collision_Light_Systems_Installation_and_Service_Manual.pdf Good enough for me. The previous owners didn't change the strobe system. They replaced a strobe power supply with an equivalent or better part. 1 Quote Link to comment Share on other sites More sharing options...
cliffy Posted April 17, 2014 Report Share Posted April 17, 2014 jetdriven- Had not seen the Whelen stuff you show. The reference to Hoskins is noted and looks good to me too. Can't see any issues now. Learn something new every day. Thanks Quote Link to comment Share on other sites More sharing options...
OR75 Posted April 17, 2014 Report Share Posted April 17, 2014 Whelen publishes a cross-reference to the Hoskins strobe power supplies here. So, equivalent parts for equivalent function. It's a PMA power supply with cross-reference to the original, no longer available, Hoskins power supply. http://www.whelen.com/pb/Aviation/System%20Requirements/Cross%20Reference%20Chart.pdf Also they detail how to intermix the Hoskins strobe tube to the Whelen power supply here. http://www.whelen.com/pb/Aviation/Catalog%20Price%20Lists%20and%20Manuals/Anti-Collision_Light_Systems_Installation_and_Service_Manual.pdf Good enough for me. The previous owners didn't change the strobe system. They replaced a strobe power supply with an equivalent or better part. the A490TCF is a new technology , available power supply and in that sense in a good thing. I wish wheelen had a simple power supply that could be synced. The Hoskins power supply can be synchronized ( yellow wire) . It is most of the time repairable. Quote Link to comment Share on other sites More sharing options...
BillC Posted June 7, 2014 Report Share Posted June 7, 2014 My tail strobe light stopped working yesterday. Is there an easy way to tell if it's the tube or the power supply? I have Whelen strobes and power supplies in the wings but am not sure what's in the tail yet. Thanks for your help. Bill Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted June 7, 2014 Report Share Posted June 7, 2014 My tail strobe light stopped working yesterday. Is there an easy way to tell if it's the tube or the power supply? I have Whelen strobes and power supplies in the wings but am not sure what's in the tail yet. Thanks for your help. Bill Just remove the tube from the tail and plug it into one of the wing units and see if it flashes. If it does then it is the power supply if it doesn't then it is the tube. Quote Link to comment Share on other sites More sharing options...
BillC Posted June 8, 2014 Report Share Posted June 8, 2014 Thanks MK. I was hoping the flash tube turned black, but that would be too easy. LOL. Bill P.S. Turns out there's an SDI strobe light in the tail. I'll open the access panel tomorrow and see what brand the power supply is. Quote Link to comment Share on other sites More sharing options...
BillC Posted June 8, 2014 Report Share Posted June 8, 2014 MK, I just read a previous post by you that mentioned that you could change the flash tube without buying the entire strobe light for about $40.00? Where were you able to buy just the flash tube? Thanks again, Bill Quote Link to comment Share on other sites More sharing options...
