tony Posted November 11, 2013 Report Share Posted November 11, 2013 Has anyone ever installed one of these? http://www.chiefaircraft.com/aircraft/oil-system-filters/filter-conversion-kits/cl-1000a-stc.html If so, we you satisified? Any issues with the installation? Quote Link to comment Share on other sites More sharing options...
Alan Fox Posted November 11, 2013 Report Share Posted November 11, 2013 Just make sure you use the correct gasket , The gasket for the screen housing will cause it to overheat... Quote Link to comment Share on other sites More sharing options...
tony Posted November 11, 2013 Author Report Share Posted November 11, 2013 you mean the gasket between the adapter and the accessory case? Quote Link to comment Share on other sites More sharing options...
Alan Fox Posted November 11, 2013 Report Share Posted November 11, 2013 Yes the one for the screen housing , and the one for the adapter housing are different... Quote Link to comment Share on other sites More sharing options...
lamont337 Posted November 11, 2013 Report Share Posted November 11, 2013 I went with the one from Aero. Same thing, right? http://www.aeroinstock.com/products/204418-156/0/11519/product_detail/index.html Very happy with it. Quote Link to comment Share on other sites More sharing options...
tony Posted November 11, 2013 Author Report Share Posted November 11, 2013 No the one you posted is the regular one which I already have; where the filter mounts in a horizontal position. For the one I posted, the filter is mounted vertical. So when you do an oil change, you can poke a hole in the filter to vent and let the oil drain back into the engine. That way when you remove the filter theoretically, you shouldn't make a mess..... Quote Link to comment Share on other sites More sharing options...
Chimpanzee Posted November 12, 2013 Report Share Posted November 12, 2013 I wanted to replace my screen with filter since I bought the plane, and initially considered an Airwolf remote. For space and other reasons I finally bought and installed the ECI angled adapter. From my experience spacing (or lack of) is a problem. I needed the long (2.5") adapter to get the filter properly situated. I would also consider changing the oil hoses. Mine were old but fine, however I reasoned that the handling and re-bending of hoses lying un-disturbed for long would only lead to trouble, so I had them all replaced with new ones. The ECI kit looks solid and came complete with all hardware and gaskets. Oil changes have become faster and less cumbersome as the filter is easier to access than the screen. Cheers Norbert Quote Link to comment Share on other sites More sharing options...
N601RX Posted November 12, 2013 Report Share Posted November 12, 2013 I've been the gallon ziplock bag trick and it works well as long as you keep it pulled up tight around the filter adaptor. I've also thought about getting or making something like this. http://www.aircraftspruce.com/catalog/topages/draintool.php?clickkey=5469 or this http://www.aircraftspruce.com/catalog/topages/oilfilterdrainer.php Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted November 12, 2013 Report Share Posted November 12, 2013 I've been the gallon ziplock bag trick and it works well as long as you keep it pulled up tight around the filter adaptor. I've also thought about getting or making something like this. http://www.aircraftspruce.com/catalog/topages/draintool.php?clickkey=5469 or this http://www.aircraftspruce.com/catalog/topages/oilfilterdrainer.php I have the second one good idea did not work well at all for me. I'll sell it ot you for 1/2 price. Maybe it is just operator error. I let the engine sit for 45 minutes and stuff rags under the filter works well enough for me. Quote Link to comment Share on other sites More sharing options...
N601RX Posted November 12, 2013 Report Share Posted November 12, 2013 I have the second one good idea did not work well at all for me. I'll sell it ot you for 1/2 price. Maybe it is just operator error. I let the engine sit for 45 minutes and stuff rags under the filter works well enough for me. What problems did you have with it? I could see a problem if it collapsed the filter instead of puncturing it. Quote Link to comment Share on other sites More sharing options...
aaronk25 Posted November 12, 2013 Report Share Posted November 12, 2013 Sorry a bit off topic but seems to make sense for those of us with oil filters that are looking for less messy oil change. I read somewhere on this form a while ago about the idea of drilling a hole in top of filter then blowing compressed air with a rubber nipple into the filter to push oil put of filter into engine. Works awesome hardly even dirty a shop towel. Maybe a teaspoon of oil. No oil running down firewall and on tire. Quote Link to comment Share on other sites More sharing options...
AF M20J Posted June 19, 2017 Report Share Posted June 19, 2017 I'm going to resurrect this old thread, as it is the closest I could find to my current question... Has anyone had experience with the Casper Labs 90 degree angle filter conversion? http://www.chiefaircraft.com/cl-1000a-stc.html Seems it is STC'd, but maybe/maybe not for Mooney Engines... Here's hoping someone else has done the research on this. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 20, 2017 Report Share Posted June 20, 2017 2 hours ago, AF M20J said: I'm going to resurrect this old thread, as it is the closest I could find to my current question... Has anyone had experience with the Casper Labs 90 degree angle filter conversion? http://www.chiefaircraft.com/cl-1000a-stc.html Seems it is STC'd, but maybe/maybe not for Mooney Engines... Here's hoping someone else has done the research on this. If your engine is an IO360A3B6D it won't work for you. Save the money and learn to change to oil without spilling, it can be done. Clarence Quote Link to comment Share on other sites More sharing options...
BDPetersen Posted June 20, 2017 Report Share Posted June 20, 2017 I'm sorry I don't recall the conversion I ordered from Spruce, but it would not fit the Mooney due to an engine mount interference problem. Even talked to the guy who made the conversion. He owned a Mooney and couldn't use his conversion on his own plane. He advised me to find a used Lycoming adapter and use it. I'm thinking it was a Casper I tried. I know it was made in FL. 1 Quote Link to comment Share on other sites More sharing options...
AF M20J Posted June 20, 2017 Report Share Posted June 20, 2017 22 hours ago, M20Doc said: If your engine is an IO360A3B6D it won't work for you. Rats. Thanks for the info. That is what I've got under the cowl... 22 hours ago, BDPetersen said: He owned a Mooney and couldn't use his conversion on his own plane. Ouch. Quote Link to comment Share on other sites More sharing options...
Greg Ellis Posted June 21, 2017 Report Share Posted June 21, 2017 On the Chief Aircraft Website, it states that it does not fit Mooney aircraft. It is at the very bottom of the description. Taken directly from the description... it will not fit on the Beech Sundowner, Traveler or Musketeer with Lycoming engines; the Piper Cherokee Series; ALL Mooney Aircraft. Quote Link to comment Share on other sites More sharing options...
Shiny moose Posted June 22, 2017 Report Share Posted June 22, 2017 Just cut a pice of aluminum to fit under the filter and long enough to drain oil outside of cowling. Slightly unscrew filter let drain for a few min, remove filter. No mess dry engine afterSent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
AF M20J Posted June 26, 2017 Report Share Posted June 26, 2017 Thanks for the tip @Shiny moose Interesting username too btw... Quote Link to comment Share on other sites More sharing options...
Shiny moose Posted June 26, 2017 Report Share Posted June 26, 2017 Grew up in Maine ( moose) and airplanes are shiny, my plane is dull but dull moose didn't sound good. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
AF M20J Posted June 27, 2017 Report Share Posted June 27, 2017 Classic. Thanks for the backstory. Quote Link to comment Share on other sites More sharing options...
JeffMirs Posted July 2, 2018 Report Share Posted July 2, 2018 (edited) delete Edited September 10, 2018 by JeffMirs Quote Link to comment Share on other sites More sharing options...
