AlanA Posted September 17, 2013 Report Share Posted September 17, 2013 I would like to replace the Questair OAT in my window with something easier to read and more accurate. Any suggestions? Is there anything which is FFA-PMA approved? Quote Link to comment Share on other sites More sharing options...
N601RX Posted September 17, 2013 Report Share Posted September 17, 2013 I used the Davtron 655. It shows OAT, pressure alt, density altitude and voltage. They also have other models that show OAT and other parameters. Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted September 17, 2013 Report Share Posted September 17, 2013 The Davtron M803 OAT, Clock and Voltage meter works well for me in the panel of the "C". I wanted a voltmeter in plain view and the M803 displays voltage clearly. The M803 would not fit into the spot in the yoke where the original 1965 "8 day" clock sat as the Davtron is deeper. Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted September 17, 2013 Report Share Posted September 17, 2013 I've also got the Davtron M655 and love it. Got it cheap (~$150) and installed myself under supervision. Whatever you get, take the time to put the probe in the correct location, which is under the wing, outboard of the main gear. We've covered this a lot so you can search up past topics here. Quote Link to comment Share on other sites More sharing options...
BigTex Posted September 17, 2013 Report Share Posted September 17, 2013 If you have a JPI or GEM engine monitor, you can get a probe and display OAT there. I'm having a new windshield installed and that's what I'm doing. Quote Link to comment Share on other sites More sharing options...
Marauder Posted September 17, 2013 Report Share Posted September 17, 2013 If you have a JPI or GEM engine monitor, you can get a probe and display OAT there. I'm having a new windshield installed and that's what I'm doing. Gary -- do you know if the OAT is considered a required piece of equipment (I don't have my manual handy) and is primary? I think it is probably only required, like the clock, for IFR flights. I have OAT on both my Aspen and JPI. Would certainly love to lose the one in the glass. It will make me just that much faster to stay ahead of Mike (201er) in his J. Quote Link to comment Share on other sites More sharing options...
BigTex Posted September 17, 2013 Report Share Posted September 17, 2013 Not required as far as I can tell... So go get'um Dusty! Quote Link to comment Share on other sites More sharing options...
