PTK Posted September 17, 2013 Report Share Posted September 17, 2013 I was very curious about the appropriateness of weighing the tail down in order to jack the nose. I just read M20-114. It is NOT recommended to use tail tie-down in order to lift nose wheel off the ground and it's precisely what many shops do! They attach this concrete weight on the tail tie down! Mooney recommends an A frame with chain hoist from the engine lift point which makes the most sense and doesn't stress the airframe or engine mounts. Quote Link to comment Share on other sites More sharing options...
mike_elliott Posted September 17, 2013 Report Share Posted September 17, 2013 I know mooney does not recommend using a tail tie down to support the weight of the engine and lift the nose wheel off the ground, but isn't that exactly what the tail does when it is flying? Help this old Civil Engineer make sense of this static problem.... 1 Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted September 17, 2013 Report Share Posted September 17, 2013 This subject was discussed recently when I reported on the $50 I spent building this hanger accessory. http://mooneyspace.com/topic/9946-tail-tiedown-weight/ Quote Link to comment Share on other sites More sharing options...
fantom Posted September 17, 2013 Report Share Posted September 17, 2013 I just read M20-114. It is NOT recommended to use tail tie-down in order to lift nose wheel off the ground and it's precisely what many shops do! They attach this concrete weight on the tail tie down! Mooney recommends an A frame with chain hoist from the engine lift point which makes the most sense and doesn't stress the airframe or engine mounts. Actually has been discussed at nauseam, and it isn't an issue. Try using the search fuction when you're 'very curious' Peter. It's not Mooney's fucctional recommendation but a liability CYA. Can't wait to see what happens when someone brings a lawsuit after an engine hoist accident. 2 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted September 17, 2013 Report Share Posted September 17, 2013 I know mooney does not recommend using a tail tie down to support the weight of the engine and lift the nose wheel off the ground, but isn't that exactly what the tail does when it is flying? Help this old Civil Engineer make sense of this static problem.... The difference is in the point load of the tail weight vs. the distributed load from the horizontal stabilizer reacting through the tailcone monocoque structure. I use the engine lift point. The IA I used this year used a tail weight but I didn't complain. Another MSC I know uses a prop sling and I don't complain about that either. 1 Quote Link to comment Share on other sites More sharing options...
yvesg Posted April 20, 2017 Report Share Posted April 20, 2017 I am about the build a jackstand to raise the wing enough to replace a tire. Anyone having the height of the tie down ring above ground? This will save me driving to the airport (40 minutes drive) and measure it. Yves Quote Link to comment Share on other sites More sharing options...
thinwing Posted April 20, 2017 Report Share Posted April 20, 2017 Have a long body..?welded fitting take a 7/16 threaded mushroom cap screw...that's an engine mount jackpoint left side of cowling ,next to cowl flap...third jack point that you could stage a disco party on wing! Quote Link to comment Share on other sites More sharing options...
yvesg Posted April 20, 2017 Report Share Posted April 20, 2017 Have a short body. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted April 20, 2017 Report Share Posted April 20, 2017 This jack (26"-43") works perfectly on our vintage Mooneys. The jack point must be about 27" from the floor. http://www.ebay.com/itm/MODEL-326-3-Ton-Alpha-Aviation-Aircraft-Jack-for-Beech-Mooney-or-Piper-/220568614930?_trksid=p2385738.m2548.l4275 Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted April 20, 2017 Report Share Posted April 20, 2017 55 minutes ago, yvesg said: I am about the build a jackstand to raise the wing enough to replace a tire. Anyone having the height of the tie down ring above ground? This will save me driving to the airport (40 minutes drive) and measure it. Yves Lots of variables, but roughly 28" at the tie down point to get the main gear off the ground. Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 20, 2017 Report Share Posted April 20, 2017 On an F there is only about 160 lbs on the tail tie down ring when jacking. Pretty sure that is not enough to damage anything by using the tail tie down ring. So I added another 160lbs to keep it down. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted April 20, 2017 Report Share Posted April 20, 2017 (edited) The first thing I did when I got my hangar in '93 was to sink a giant lead anchor in the floor with a hoist bolt. It has a chain to the tail as we speak. Edited April 20, 2017 by N201MKTurbo Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 20, 2017 Report Share Posted April 20, 2017 I could Hilti Gun a plate to the floor, but easier to spend $12 on sacrete Quote Link to comment Share on other sites More sharing options...
yvesg Posted April 20, 2017 Report Share Posted April 20, 2017 Thanks folks. I will let you know how things went in about a week.... One last question: How many inches of jack play do you need to rise approximately for the wheel to rise up assuming pucks are in good shape? Yves Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted April 20, 2017 Report Share Posted April 20, 2017 10 minutes ago, Yetti said: I could Hilti Gun a plate to the floor, but easier to spend $12 on sacrete But not as elegant Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 20, 2017 Report Share Posted April 20, 2017 Seems to be about 4-6 inches per side to get the whole plane up with a tail tie down. If you are just doing one side at a time, it might be a bit less. Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 20, 2017 Report Share Posted April 20, 2017 1 minute ago, DonMuncy said: But not as elegant Ya but when I need to set a post I can just run over and grab a bag :-) Quote Link to comment Share on other sites More sharing options...
RLCarter Posted April 20, 2017 Report Share Posted April 20, 2017 43 minutes ago, Yetti said: Ya but when I need to set a post I can just run over and grab a bag :-) I would have to check the FAR's, but I seem to remember that once something is used in or around your plane it can no longer be used for its intended use 1 Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted April 20, 2017 Report Share Posted April 20, 2017 I might have spent $50, probably less. Quote Link to comment Share on other sites More sharing options...
Hank Posted April 20, 2017 Report Share Posted April 20, 2017 My last two annuals, I've stacked cases of oil and tool rolls across the stabilizer. Holds it pretty well. Quote Link to comment Share on other sites More sharing options...
Shadrach Posted April 20, 2017 Report Share Posted April 20, 2017 On 9/17/2013 at 1:45 PM, KSMooniac said: The difference is in the point load of the tail weight vs. the distributed load from the horizontal stabilizer reacting through the tailcone monocoque structure. I use the engine lift point. The IA I used this year used a tail weight but I didn't complain. Another MSC I know uses a prop sling and I don't complain about that either. The same could be said of the hoist point. It's really only rated for the engine weight. Not designed to carry the airframe, fuel and an A&P in the cockpit for the gear check. Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted April 20, 2017 Report Share Posted April 20, 2017 True, but the shear capability of the bolt, the ring, and the engine case greatly exceed the load during jacking. And that load is carried through 4 bolts and the engine mount, and not a single point in the wimpy tail skin area. I'm a structural analyst and don't sweat any of the common techniques... Sent from my LG-LS997 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
47U Posted April 20, 2017 Report Share Posted April 20, 2017 Yves, You're making me really nervous talking about jacking up one wing far enough to get a tire off the ground. The jack adapters do not attach solidly to the jack and the chances for upset are too great a risk. There's a picture somewhere of a Mooney with the jacks sticking up through the wings. If your brake calipers have not been rotated (per the LASAR STC) then there's plenty of room to jack the gear at the axle on the outboard side. I use a car scissors jack, about $20 at Harbor Freight. Using the scissors jack, the gear leg is raised up only an inch or so to get the tire off the ground and the aircraft is much more stable. In my opinion... Tom 1 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted April 20, 2017 Report Share Posted April 20, 2017 1 hour ago, 47U said: Yves, You're making me really nervous talking about jacking up one wing far enough to get a tire off the ground. The jack adapters do not attach solidly to the jack and the chances for upset are too great a risk. There's a picture somewhere of a Mooney with the jacks sticking up through the wings. If your brake calipers have not been rotated (per the LASAR STC) then there's plenty of room to jack the gear at the axle on the outboard side. I use a car scissors jack, about $20 at Harbor Freight. Using the scissors jack, the gear leg is raised up only an inch or so to get the tire off the ground and the aircraft is much more stable. In my opinion... Tom Mine sit firming down inside the bowl at the top of the jack. Once the jack mates with the wing there is no way that adapter is going anywhere. -Robert Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted April 21, 2017 Report Share Posted April 21, 2017 13 hours ago, Bob_Belville said: I might have spent $50, probably less. And semi elegant. 2 Quote Link to comment Share on other sites More sharing options...
