mooneyflyer Posted August 29, 2015 Report Share Posted August 29, 2015 I have the Moritz Gauge in my Eagle. It has analog/digital indicators for Oil Temp/Oil Pressure/EGT/CHT.... It's on an instrument dimmer switch. When I shut the dimmer switch to OFF, my Oil Temp and CHT brighten up to full bright. Is this correct? Or a failure? Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted August 30, 2015 Report Share Posted August 30, 2015 I can check later today and let you know. Are the instrument dimmers you are referring to the ones that are low on the copilot panel? Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted August 31, 2015 Report Share Posted August 31, 2015 I have the Moritz Gauge in my Eagle. It has analog/digital indicators for Oil Temp/Oil Pressure/EGT/CHT.... It's on an instrument dimmer switch. When I shut the dimmer switch to OFF, my Oil Temp and CHT brighten up to full bright. Is this correct? Or a failure? My Eagle does the same thing and I consider it normal. I only use the dimmer at night and like the brightness in daylight when the dimmer is off. Quote Link to comment Share on other sites More sharing options...
