JaredDavis Posted March 31, 2015 Report Share Posted March 31, 2015 Hi, Has anyone changed out a Heim bearing on an Aileron Push tube? The bearing that connects to the aileron has a lot of movement. Any hints for the A/P? The plane has two different push tubes. One is the original style #: 915012 with M34-14 bearing locked by two rolled pins. This is the bearing that needs to be replaced. The other side has a newer tube from 2001 #730048-905. Anyone have a good source for the rolled pins # RP-A52-028-125-0.687? I think MS16562-36 is the closest pin. It is .75 long vs .687. Should I just replace the 915012 with the newer style? Quote Link to comment Share on other sites More sharing options...
aerobat95 Posted March 31, 2015 Report Share Posted March 31, 2015 I replaced mine about 2 years ago with the newer style and I got them from Lasar. My A&P said it was a pain in the butt to get the fitting in the wing done. I think he charged me a few hours labor to do it. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted March 31, 2015 Report Share Posted March 31, 2015 There is no need to do it. It won't make the plane fly any better. The ailerons both have up force on them which stretches the tubes and takes all the slop out of the system. The aileron tubes are always pulling. The only place there can be backlash is between the yoke and the center bellcrank.. Quote Link to comment Share on other sites More sharing options...
aerobat95 Posted March 31, 2015 Report Share Posted March 31, 2015 my bearings were worn....just saying Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted March 31, 2015 Report Share Posted March 31, 2015 On my E model I changed the rod ends on the control rods for the ailerons it required some machining to make it happen. The biggest pain was installing the control rods and getting the inboard rod end lined up and bolted together with the upside down and blind access. Mooney put the adjustable end inside the wing which is the hardest place to reach. If it were on the aileron side adjustments would be a lot easier. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted March 31, 2015 Report Share Posted March 31, 2015 To adjust those rod ends, remove the bolt where the rods attach to the center links in the belly. Then rotate the whole rod. it is real easy that way. Quote Link to comment Share on other sites More sharing options...
MyNameIsNobody Posted March 31, 2015 Report Share Posted March 31, 2015 How many hours on your airframe? Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted March 31, 2015 Report Share Posted March 31, 2015 My F is 6k + my former E was under 3k hours. N201 thanks for the suggestion too bad I ddin't think of that. Quote Link to comment Share on other sites More sharing options...
JaredDavis Posted March 31, 2015 Author Report Share Posted March 31, 2015 3.8K hours. I think I'll order up the new style tube + bearings. Thanks Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted April 2, 2015 Report Share Posted April 2, 2015 Adjustment is one thing. But I'm assuming the motivation is because the link is wearing. Meaning there is slop there on the aileron when you hold the yoke steady. Even the Heim wear out. I'm going to replace mine in the hose gear door. I can wiggle the doors around on the heim bearings themselves. -Robert Quote Link to comment Share on other sites More sharing options...
Guest Posted April 3, 2015 Report Share Posted April 3, 2015 On my E model I changed the rod ends on the control rods for the ailerons it required some machining to make it happen. The biggest pain was installing the control rods and getting the inboard rod end lined up and bolted together with the upside down and blind access. Mooney put the adjustable end inside the wing which is the hardest place to reach. If it were on the aileron side adjustments would be a lot easier. If the forward end of the aileron rod is not worn, you don't need to remove the bolt from the bellcrank. With a 7/16" wrench crack the check nut loose and spin the rod off the bearing, after having removed the aft bolt at the aileron. Replace the aft rod end and screw the rod back on to the still in place forward rod end. Clarence Quote Link to comment Share on other sites More sharing options...
